I tested a 50 amp pedestal today before hooking up and got a concern. It had 120 volts to each hot leg but also 120 volts between the ground and neutral. I moved to another site but I am wondering wha...
I agree tough to believe. When you measured 120 vac on the hots was that from neutral or ground to a hot? If from neutral to a hot it implies ground was tied to a hot.
