I tested a 50 amp pedestal today before hooking up and got a concern. It had 120 volts to each hot leg but also 120 volts between the ground and neutral. I moved to another site but I am wondering wha...
Not sure how that could happen-- would need exactly where you read what:
If each outer is hot (as it should be) AND either the center round (ground) or center straight (neutral) was hot, then CHECKING BETWEEN EITHER HOT AND WHICHEVER OF THE CENTERS WAS HOT WOULD EITHER READ ZERO VAC OR 240 VAC.
