Lurker52ExplorerMay 03, 201550 amp hook upI tested a 50 amp pedestal today before hooking up and got a concern. It had 120 volts to each hot leg but also 120 volts between the ground and neutral. I moved to another site but I am wondering wha...Show More
BobboExplorer IIIMay 04, 2015We really need more readings. We need: NEUTRAL to L1. (should be 120)NEUTRAL to L2. (should be 120)L1 to L2. (should be 240)GROUND to L1. (should be 120)GROUND to L2. (should be 120)GROUND to NEUTRAL. (should be 0)Only with this info can we try to diagnose the problem.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
