When plugging into 50 amp i only get one leg. If i put on the dogbone and plug into 30 amo i get all plugs working. Volt meter says both poles of plug are hot. Got a new cord still missing one side...
Using a voltmeter make sure both hot pins of the 50 amp outlet have 120 vac. If so, plug in your 50 amp cord (with it disconnected from the RV) and check to see that you have 120 vac on both hot pins of the cord at the trailer end.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
