tbax46
Apr 07, 2022Explorer
50 amp missing
When plugging into 50 amp i only get one leg. If i put on the dogbone and plug into 30 amo i get all plugs working. Volt meter says both poles of plug are hot. Got a new cord still missing one side...
LittleBill wrote:BB_TX wrote:
Using a voltmeter make sure both hot pins of the 50 amp outlet have 120 vac. If so, plug in your 50 amp cord (with it disconnected from the RV) and check to see that you have 120 vac on both hot pins of the cord at the trailer end.
to clarify this statement. if your measuring hot to hot, it will be 240v. if your measuring hot to ground/neutral it will be 120v
