Our Alpenlite 50 amp cord is hard wired directly to the converter and the cord stored in the small compartment in the picture. When hooking up to shore power the cord must be pulled through a small op...
The 50 amp cord that is wired into the load center is a four wire assembly--two "hot" wires, a neutral, and a ground. You would be better off installing a power inlet on the outside of your 5'er and then adding the correct male plug onto the cut shore cord. All 50 amp devices I've bought recently have a pictured schematic in the product box. If you are unfamiliar with wiring, this may be a job better left to someone with experience.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
