Our Alpenlite 50 amp cord is hard wired directly to the converter and the cord stored in the small compartment in the picture. When hooking up to shore power the cord must be pulled through a small op...
You have a really simple solution. Cut your cord so that it will just reach the ground when out of the RV. Then buy a RV plug and RV receptacle at your local hardware store. They are the same plug and cord end as the stove used everywhere in this country.
The plug is 4 wires. Black and red wires go to the brass terminals.
Green wire goes to the green terminal.
White wire goes to the silver screw terminal.
Pretty simple!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
