SH
Jul 03, 2015Explorer
50 amp plug
Our Alpenlite 50 amp cord is hard wired directly to the converter and the cord stored in the small compartment in the picture. When hooking up to shore power the cord must be pulled through a small op...
SH wrote:OK, I reviewed your pictures and I see where your cord exits presently. Was confused by the access hatch.westend quote wrote:
Can't you mount a power inlet on the same exterior panel that houses the present shore cord storage? If nothing else, buy a piece of King Starboard or sililar and cover the present hole. Use this new piece for the power inlet mounting.
I could but that hole exits underneath at the top of the j-panel. No easy way to reach up plug in a cord. The way it is now I simply drop the current cord to the ground through the hole.
I guess I can leave it alone but boy does that cord get difficult to stuff in that compartment in colder weather!
