LouLawrence
Jul 25, 2021Explorer II
There are also adapters that will allow you to plug into 30 amp campground plugs (rarely available, but there are some) and use your 50 amp plug with that. You still don't have 50 amp service but you would have 30amp service on each leg (so nearly 60 amp if balanced properly).
50 amp cheater adapter
This generally will not work if you plug into a 30 and a 20 if the 20 amp circuit has a GFCI as it will usually trip immediately.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
