time2roll
May 25, 2018Nomad
Just need to move the meter up the wire to each connection and see where you lose voltage. Maybe just wiggle and reset the connectors.
However I would first check the common duplex you are plugged into to verify the supply voltage is not sagging. Check with the RV still plugged in.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
