- ScottGNomadAssuming it disconnects at both ends, has anyone ever considered making a second, shorter cable? A length that would suffice most of the time and then when you need something longer, get out the original cable.
- joebedfordNomad IIIGetting it out is easy. Winding it up especially when it's cold, is the hard part.
- CA_TravelerExplorer IIICoil it in a figure 8 and you won't have the typical twisting problem.
Also if you have the typical plastic coated cord then a new rubber cord will be more flexible and the old cord will be a spare or extension. - donn0128Explorer IIMine goes in a medium laege tote in the front storage box.
- corvettekentExplorerFor $600 I can do without the Cablemaster, it is just not that hard to coil up an put away.
- Johno02ExplorerA good pair of work gloves. Lay cord out flat, then coil it into the storage bay. At hookup, just grab the end and pull.
- 1492ModeratorMoved from Forum Technical Support
- Old-BiscuitExplorer IIII carry a 5 gallon bucket(home Depot bright orange)
My 50A anaconda cord gets coiled up in bucket and then placed in back of truck bed between hitch and tailgate. - pianotunaNomad IIIThere are powered cord storage reels. Not cheap--but effective.
- Executive45Explorer IIIMy coach has the Cablemaster RLC unit which powers the cord in AND out, making both 'chores' less hectic....Dennis
Cablemaster
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
