I need to replace the power cord on my fifth wheel trailer. The one I got with it is so stiff, it is like trying to coil a board. Can anyone recommend a type of cable that will be more manageable?
Does the description list the material for the outer covering? Rubber is the most flexible (SOOW), thermoplastic is the stiffest one (STOOW). I am assuming that you are shopping online. If you are able to actually touch the cable, you can read the markings on it. SEOOW is the elastomer cover. That is not as flexible as the rubber, but is way better than the thermoplastic.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
