BFL13
Jan 24, 2015Explorer II
Lots of ways to do it, but it depends on your camping scenario what to do.
You can have a big enough inverter to run everything 120v all the time and just use a standard battery charger to keep the batts up whenever you have shore power or gen.
With a small rig you can just use the (perhaps three) receptacles of the inverter to run extension cords from (which can have more receptacles on them with power bars) and not bother with any breaker panel and any actual 120v wiring. Works if you can keep the wires behind things.
Or you can do it all up like most RVs or a small house. Depends what the whole idea is.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
