BFL13
Jan 24, 2015Explorer II
"You do not want to run a microwave from a inverter. IT is to large of a load for most battery banks, and will quickly discharge the battery anyway. Use a generator to run the microwave, or use a stove with a oven."
Our new to us 1981 Truck Camper now has two used T-1275s from 2011 (rated 150AH each for 300 total--I am getting about 270AH on these ones now) and a 2000w MSW inverter. Stuck in a "1000w" microwave and we are good to go. Can also use a toaster or a kettle, same as in the 5er with the same inverter.
Of course you have to manage your usage, but that does not limit you very much.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
