bkirkpatrick
Jan 27, 2015Explorer
Don't let the pictures get to you. The converter is a separate unit that sits behind the fuse panel. You do not need the entire package as in the link. That is for a trailer that does not have one at all. If you are "gutting" the trailer, then have at it. If you plan on leaving the original panel, don't wast your money/effort on a completely new setup. If you have seen the converter, it is a box that sits behind the 12v panel somewhere. Just pull your old one and replace with the powermax or similar.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
