theoldwizard1
Oct 14, 2016Explorer II
Save yourself a LOT of money. Use 2-2-2-4 "Mobile Home Feeder" (MHF) cable. It is aluminum and can be direct buried it required. Where it is above ground, including inside buildings, you must install it inside conduit. (NM-B 6/3 is $2.15/ft, MHF 2-2-2-4 is $1.17)
Double check that the breaker and outlet connection points can handle 2 gauge wire.
HD and Lowes don't always have it, but you can get it cut and deliver from Wire and Cable Your Way
