Bumpyroad wrote:
what is "reverse polarity" on a 50 amp outlet? I can see on a 30 amper where the hot and neutral could be reversed, but on a 50 amp outlet if one of the hots was switched with the neutral making the neutral hot, you would have a hot to hot connection???????? wouldn't that be sort of a "mess"?
bumpy
No different than at your house where you typically have a 240 VAC service entrance with 2 - 120 VAC branches out of phase.
The transformer secondary acts as a voltage source and unless the 2 hots are shorted together, there won't be an issue.
EDIT: Poor spelling... :(
