i have a 50 amp motor home, my question is I would like to connect a 50 amp plug through an adapter to 110 house current. Nothing other than a refrigerator 24 hours prior to leaving for a trip, and l...
And don't forget that your MH should be 'level' when running an RV Absorption Fridge so you don't cause any damage to it.
Also if this 15/20A household outlet you are going to be using is GFCI or GFI protected it may trip. Which can be a whole new issue. Bad extension cord(s), bad adapters, bad elements (fridge/water heater). Hopefully all's good
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
