trtog7ExplorerOct 15, 201350 amp to 15 ampGoing to buy a RV with 50 amp service Only have 15amp at home Is it possible to downgrade the 50 to 15 to keep batteries full when vehicle not in use
wolfe10ExplorerOct 15, 2013Agree, perhaps "slamming" is too strong a word. But larger inverter/chargers can charge at up to 150 amps if the batteries are discharged.I don't see the advantage to "rapidly charge" them if you are going to be plugged in 24/7.And, limiting the charge rate also allows you to use other 120 VAC appliances while on that 15 amp power supply.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
Related Content30 Amp VS 50 AmpDIY 50 amp to 20 amp pigtail50 AMP TentsHow does 50 amp work?80 amp converter and eu2000i
