trtog7
Oct 15, 2013Explorer
50 amp to 15 amp
Going to buy a RV with 50 amp service Only have 15amp at home Is it possible to downgrade the 50 to 15 to keep batteries full when vehicle not in use
Kiwi_too wrote:Good point as the typical 15A plug is one of several on a 20A CB. So if the CB trips you'll need to use plan B.
Another thing to consider is what else is on the circuit this 15 amp plug is on? If this is on a gang with a freezer or other item, the freezer compressor could put you over the amps a pop the cb.
Consider putting in at least a 30 amp cd, line anp plug.
