htwheelz67's avatar
htwheelz67
50 amp to a 30 and 20 out how to do? HELP!
I'm adding a second ac to my WW trailer, it has a 30 amp service, I am wiring the 2nd ac with seperate wiring and load center and breaker out of the load center will be a plug for the ac. I was looking at this....splitter cable
plus a 50 amp ext cable vs 2 cables, I figure I can make my own but at the end of a 50 amp cable. I am unclear how to do it. I want one 30 amp outlet and one 15/20 amp outlet, I'm using 2 dometic hi eff a/c's so they will each run off 15 amp breakers. I'm not too proficient in 240 volt 4 wire wiring.
