Hawk9
Jul 13, 2013Explorer
50 AMP
A friend of mine has a an outlet and also the plug for a 50 AMP, the Red and White wires are mis-crossed. What will that do to his RV if he hooks it up? ...Thank you! Moved to Tech Issues forun fro...
donn0128 wrote:
More than likely he has 50 amp 220 volts if it is at a house. What will happen is it will destroy everything electrical in his RV if he plugs it in. RV's use 50 amps 120 VAC. It is different.
