Hawk9ExplorerJul 13, 201350 AMPA friend of mine has a an outlet and also the plug for a 50 AMP, the Red and White wires are mis-crossed. What will that do to his RV if he hooks it up? ...Thank you! Moved to Tech Issues forun fro...Show More
TyroneandGladysExplorerJul 15, 2013And when you are absolutely 100% sure that is correct use this And then each and every time you hook up anywhere
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related Content30 Amp VS 50 Amp50 AMP TentsHow does 50 amp work?DIY 50 amp to 20 amp pigtail3 prong 50 amp plug to 4 prong 50 amp ????
