A friend of mine has a an outlet and also the plug for a 50 AMP, the Red and White wires are mis-crossed. What will that do to his RV if he hooks it up? ...Thank you! Moved to Tech Issues forun fro...
The real problem comes from the original post “the Red and White wires are mis-crossed”. What does that mean? We have to assume at the terminology used!
The real answer to the original post should have been “If you don’t know what you are talking about, call an electrician!
Red wires generally don’t exist in 120 volt circuits. I know my post was based on a pure guess at what the original post meant, but at least it did start with the proper phrase, “DO NOT PLUG IT IN”
