jrnymn7 wrote:
For me it's not so much a need for a longer bolt, I just find it very awkward to work with the (upside down) bolt and lock washer, as is. It's just so much easier to place rings over a stud and then fasten things down with a nut. (I guess I'm somewhat of a spaz too, in that regard! lol)
Where I am lacking space for enough rings is on the pos terminal stud. When I switched to the heavy duty rings, I found I could barely get two battery cables and a few thin rings on the stud, and that's using a shallow nut. So now I'm considering my options for that, as well. I will need to hook up 3 heavy duty rings and at least a half a dozen thin rings.
Stack a few on one nut and bolt with a fat wire over to the next nut and bolt to stack the rest and then from there, just one really fat wire over to the battery pos post. That gets you Mex's one ring terminal (lug) per battery post.
