time2roll
Jun 22, 2015Nomad
The circuit is overloaded. You really need to plug into a 20 amp dedicated circuit. 30a would be far better. Not a shared 15 amp circuit even if some people get this to work at times.
Has nothing to do with your adapters.
Is the main panel close by? If so and you will be doing this frequently you may as well haul out an electrician and have a 50 amp outlet installed.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
