wolfe10
Dec 04, 2015Explorer
No problem using it. By the time power goes through the adapter, it will have the same configuration (SINGLE HOT, NEUTRAL and GROUND) as your 30 amp (dropping one of the 50 amp's hots).
Yes, there will be more amps AVAILABLE, but you can not and will not be using them as your total draw will still be limited by your 120 VAC breaker panel's master breaker which is 30 amps.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
