RoyB wrote:
If your 55AMP converter/charger is the WFCO WF-8955 then just note not many folks can get those to go into the BOOST 14.4VDC charge mode. I never could get my WFCO WF-8945 to do it so I replaced it with the PD9260C 60AMP converter/charger. It works everytime now...
If you want to get it charged in a three hour time span then you have to use 14.4VDC with a current capacity of around 20AMPs. When the GP24 Interstate battery sees 14.4VDC it will start drawing around 20AMPS DC from your converter/charger. The 14.4VDC will stay up around two hours and then switch down to 13.6VDC for an additional hour. Then you will be at your 90% charge state.
If you are only putting 13.6VDC on the battery terminals it will take those times listed in the PROGRESSIVE DYNAMICS Brochure report listed under the 13.6VDC side.
The battery will determine how much current it wants to draw. You just have to have that much current available to use to get the times noted in the report.
Roy Ken
RoyB, thank you! Some good info! I've been clear on the importance of achieving a 14.4 vdc charge voltage in terms of charging time. So, from your experience, what kind of voltage do you typically read on the terminals of a very discharged battery (less than 25%) when 14.4 vdc of charging voltage is being applied with your PD9260C? I assume the actual amount of this voltage drop is determined by the current capacity of the converter/charger (with everything else being equal)?
Anyhow, I supplied as much info as I had (using a VM and my PI EMS 120 volt current readout) which I hoped would be enough info to determine a rough state of charge. Apparently, it's not nearly enough. Guess I'm gonna have to check the SOC by brute force, with a large, verifiable load, then count the minutes till the battery voltage drops to 11.9 - 12.0 volts.
