MFL
Feb 05, 2021Nomad II
fj12ryder wrote:bpounds wrote:This is very often the case. To retorque a nut/bolt, the nut/bolt should be loosened and then torqued back to spec. Personally if I was worried about the torque of my lug nuts, I'd dial back the torque wrench to 10-15 lb.ft below the spec and see if they're tight at that setting. If they are I'd call it good.
People who constantly re-torque things are their own worst enemies.
I like that idea Howard, just backing off a bit to check!
Jerry
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
