time2roll
Feb 05, 2021Nomad
Are these oem studs? OK my story is just cheap materials. My oem drums would always have a squishy feel when applying 105 ft/lb like the bolt was stretching a bit too much. Spec was 90-120 and I was setting them at 105. Never lost a stud but it did not feel right. Fast forward to replacing the drums with disks and it is like night and day. The studs on the discs tighten and click right quick and firm with no extended tightening. Same size stud.
For your buddies I recommend all lugs should be replaced if you replace one. (or just get disk brakes already)
I don't think it is the stabilizer between the tires.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
