fj12ryder
Feb 06, 2021Explorer III
Lynnmor wrote:But if the torque wrench clicks and the nut doesn't move, that doesn't mean the nut is at proper torque. A bolt/nut needs to be moving to get the torque correct. If the wrench clicks when the nut is stationary, you're looking at static friction, not necessarily proper torque setting. The bolt/nut has to be moving when the wrench clicks.Bird Freak wrote:
I was a Snap-on tool dealer for about 4 years. If you keep checking them without backing them off first you stretch the bolt a little each time.
Quite the opposite, if the bolt is checked and it didn't move, it can't stretch. If it did move, then you are just doing a proper torque.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
