fj12ryder
Feb 06, 2021Explorer III
Bird Freak wrote:Well, that is the proper way to use a torque wrench. Using it on a stationary nut isn't correct. As you tighten the nut, when the wrench clicks, it's correct. Stopping and checking is not the way to do it.Lynnmor wrote:Problem is most folks don't know how to properly use a torque wrench and will move it a bit.Bird Freak wrote:
I was a Snap-on tool dealer for about 4 years. If you keep checking them without backing them off first you stretch the bolt a little each time.
Quite the opposite, if the bolt is checked and it didn't move, it can't stretch. If it did move, then you are just doing a proper torque.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
