time2roll
Aug 05, 2014Nomad
You have an open circuit between the battery and the landing gear circuit.
Apparently the tow vehicle shares that wire... and is probably not charging the battery in transit.
We cannot see or test the connections. Good chance it is a circuit breaker that needs reset or replaced or a loose or dirty connection. This is all going to be close to the positive battery terminal. Although it could be a couple feet away or under the trailer.
You need to tell us what you see or better yet post a pic.
Do you have a volt meter or test light?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
