SDcampowneroperator wrote:
Electric jack legs are connected to each other by one motor via a jack shaft with bevel gears on each end. They cannot be 'retimed' to each other by any other way than removing the shear pin through the bevel gear on one end of the shaft, putting it back in when the jack legs are equal.
Never top or bottom out the legs, that will at least blow the breaker, at worst strip gears or burn out the motor.
The other campers advice was not correct.
Don't have to do anything to bevel gear
Cross tube is two piece held to drive shaft at each end by bolt/nut
Remove easiest bolt/nut to access rotate cross tube to drive still connected end up/down then reinstall bolt/nut thru cross tube
See pg 6...Item #19 HERE
