Camper117's avatar
Camper117
5th Wheel Landing Gear
While camping this weekend, I mentioned to a fellow camper that my landing gear was out of sync (one foot hitting the ground before the other). He said if I were to raise the landing gear all the way up, the feet would realign and hit the ground at the same time, provided the ground was level.
I decided to try that when I got home today. So, I raised the landing gear up all the way. When it reached the upper limit, the motor stopped and hasn't worked since. So I used the manual crank and got unhooked. I have a hard time the swithc picked that exact moment ot go out.
Does anybody have any ideas? Thanks
  • Yeah, that was really bad advice.
    Generally you can pull the bolt that connects the cross shaft and even up the legs that way.
  • Most landing gear motors are 30 amps...most switches are rated for 16 amps. Mine just failed on a 6 month old rig
  • That person gave you some very bad advice. What you did when you hit the top was probably blowing the fuse for the motor. They do not even out when you go to the top. I'm not talking about hydraulic jacksonly the gear driven Jacks
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
