CA_Traveler
May 11, 2014Explorer III
rockwind1 wrote:7Ax120V=840watts. You have to draw 840W out of the battery. So 840W/12V=70A. You likely lose 10% in the inverter so you're drawing about 77A.
thank you, I just saw that capacity was 200 for each pair, but not getting the 7 amps to 70 amps vdc but I am sure you are right. I actually have isolated each "pair" and they both do the same thing.
am I correct in assuming that going below 12.3 volts is less than 50%?
After drawing a load the batteries have to rest with NO loads for about 2 hours in order for the voltage to accurately reflect SOC. When did you measure the 12.3V and any loads at that time?
You have unknown batteries. Take them to a good battery shop for load testing.
A voltmeter will only tell you so much about SOC. A battery monitor provides a much better understanding.
I agree with others that it doesn't seem like they are being fully charged. The Truecharge is an excellent charger, however, so something doesn't seem right.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
