pyrosecur wrote:
BarneyS wrote:
pyrosecur wrote:
Snip...
PS I have no idea why it shows as a new member, maybe because I do not post often (too busy camping :) )
Number of posts:
0-49 -> New Member
50-199 -> Full Member
200- -> Senior member
Barney :)
Thanks for the info
PS do you know where I can see how many posts I have made ?
Pick any of your posts in this thread and on the left (under your name) click on "View profile" there you will see you have made 32 posts.
As far as your short I would look again at that generator wire. I'll bet the wire rubbed through on a sharp metal edge to cause the short. Moving the wire around while checking moved the cut away from the sharp edge. Unfortunately wire has a tendency to move back into it's original position over time. So he short (if one exists) could occur again.
