Muddydogs's avatar
Muddydogs
6 volt question
Just set up a charging station at work to keep vehicle and ATV battery's charged over the winter or when rigs are in long term storage. The heart of the system is a Battery Tender 10 station charger, specs on this charger are 2 amp, 14.75 absorption and 13.2 float.
I also have a couple 6 volts 242 ah interstate battery's that need charged. The 12/6 volt charger I have is only rated for 14ah battery's and is only putting out 6.2 volts hooked to a battery that read 5.9 volts before being hooked to the charger.
I'm thinking I need a better 6 volt charger but in the mean time I was wondering if I would be better off hooking the battery's up in series and using the 12 volt charger on them?
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
