bpounds wrote:
noteven wrote:
4 x 6v only giving 12 v must mean they are half worn out in only 7 years. So one 12 v would be good for umm 3.5 years?
Yabut, it is never a linear scale of life with batteries.
I just pulled out 2 UT2200 Interstate that were 10 years old.  Still doing the job, but I would rather change them out before I'm stuck somewhere doing it at gunpoint.  I don't trust Interstate anymore, so they were not an option for me.  I got tired of the monthly maintenance too, so I went with AGM this time.  At $500 for a pair, I'm not certain it will be worth it, but time will tell, and it is only money.  You guys can limp along on club store batteries if that's what floats your boat.
If you didn't like the "monthly maintenance" (assuming you did that properly) you will LOVE AGMs, which require more care and feeding to do it right.
Wade through the " 20% rule" and the "0.5a/100AH rule" and supply yourself with the necessary tools to meet all that.
I use my Trimetric and an adjustable voltage PowerMax LK of sufficient amps to meet the 20% rule, but there are other ways of course.
I thought it was a lot easier with my previous set of Wet batteries -some 6v and a pair of T-1275 12v.  Only reason to have the AGMs now is I need to keep them inside where the fumes of a Wet would not be acceptable.
Having had to get the AGMs at extra expense (because of them being inside), I do try to do it right--but it is not a "hands off, automatic" process.  It means being extra careful to follow the "rules".
