CA_Traveler
Jun 02, 2015Explorer III
Batteries will charge at a much lower voltage than 29.6V and even below 28V but it's not the optimal charging.
A somewhat analogous situation would be to charge a 12V battery with a 30 cell/15V panel. Wonder why a 36 cell panel is normally used... One of the benefits of MPPT is the conversion of lower amps to higher amps and a 60 cells/24V setup doesn't provide that so perhaps better to just use PWM.
BFL wants to use the setup to charge both 12V and 24V while most of just setup for 12V charging with no further thought.
So perhaps 60 cells/24V is a option BFL whom I think sleeps with the battery in his bed. :) But for the average person that spends a lot less time battery tending it's a marginal approach. But then again there is always new knowledge to absorb.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
