Salvo
Jun 02, 2015Explorer
Don't forget there needs to be a voltage differential inside the mppt controller. It could be 1V or more. In other words, when in mppt mode, the input to the controller needs to be at least 1V greater than the output.
My mppt plot (below) has problems around noon and a bit later. Even though that's a 36-cell panel, I believe it's starting to run out of voltage headroom (Vmp-Vbat). Charging current isn't as high as it should be. At 8 in the morning the headroom is 4.3V. At 12:30 headroom drops to 1.83V. The battery voltage was held constant at 12.2V throughout the test.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
