Kiki_Angel
Dec 14, 2014Explorer
tenbear wrote:
Be aware that the size of your battery bank should play a part in your decision of what size inverter to buy. A 600 watt inverter at its full rating will draw 50 plus amps. If you have a single battery, it will be down to 50% in less than one hour. If only drawing less than 300W, a 300W inverter will be more efficient than the 600W inverter.
I have two 6 volt batteries 205 AH. It was suggested I should get a 1000 watt inverter.
Do I have enough capacity to consider the larger unit?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
