mena661
Dec 15, 2014Explorer
NinerBikes wrote:In my case, it's easier just to run them off an inverter than to run new 12V wires/cig plugs to the TV's (they don't have bricks anyways). Also, can't run the receiver and DVD players on 12V so I have to use an inverter anyways. Some other stuff runs on 120V only too. I plug the shore cord directly into the inverter and turn off all breakers except the receptacles (they're all normally off anyways...I only leave the MegaWatt's breaker on at home...easy to remember).
Then if you have a 120v Samsung TV with a 12 or 14v power brick in line, you can also run that direct to get it off the inverter.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
