CA_Traveler
Nov 05, 2015Explorer III
Your numbers are good. At maximum sun add heavy loads to see what your controller will produce. I got 49A out of 750W, clear day in March in Phoenix, flat mounted panels with MPPT controller.
"I see my gains on the solar seem to go with how low I draw the batteries down and how much I use during the day."
That's normal as the controller will not produce unneeded power.
As a test since you have utility power you could draw more power than the solar can produce all day to see the numbers and then turn on the charger at night.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
