RoyB
Nov 05, 2015Explorer III
I'm hoping my OFF-ROAD POPUP roof will allow me to install two 120WATT panels in the front along side of the Fantastic Fan and maybe a 240WATT panel on the rear of the roof just behind the roof mounted air conditioner..
All I am looking for is a good 20AMPS plus during the high sun to supplement my battery charging when using the 2KW Generator each day when camping off the power grid. My daily draw from the batteries usually starts at 6PM to 11PM where we will pull a good 20AMPS or so continuous. Then of course we always have our 1-2AMPS of parasitic drains. All of this drops my current battery banks of 255AHs capacity down to the 12.0VDC level at 8AM each morning which is around the 50% charge state. This is when I want to start my re-charge using my 2KW generator to power up the PD9260C converter/charger for my three hour run. Using the planned solar panels I think I will be able to only need the generator for the first one hour charge run.
Being always around public camp grounds here on the east side of the US that seem to all have generator run time restrictions I need to get my batteries re-charged as quick as possible each day...
My battery bank will want to draw around 50AMPS PLUS DC current when first hit with 14.4VDC which make me have to use the generator for sure until the charge current starts tapering back. When it gets to the 8AMPS DC Current demand than I can stop using the generator and let the solar panels finish my re-charge state with my daily goal being 90% charge state before I run out of high sun each day.
I should be able to do this with the 20AMPS DC Current with high sun...
Some say I will do better than this which is great. I still will have to keep both systems of charge however as I will not even think about starting my day/night run off of the batteries unless I have a 90% charge state. Everytime I do this it always gets dark on me around 10PM at night. When my DC VOLTS monitor panels its 12.0VDC I shut down the batteries until i can run the generartor again.
I'm still in the planning and thinking stage here haha...
When I get my newer batteries soon I will have to get going with this project...
Sounds like you are doing great with your new solar setup...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
