BFL13
Nov 06, 2015Explorer II
Panel heat loss means you don't see rated wattage even when it is aimed at the sun. Typical loss of 0.43% per degree above 25C means 0.43 x 20 = 8.6% at 45C (often quoted as "normal" operating temp)
250w panel at 25C is now 21.5w less at 45C = 228.5w
(that's with ambient 25C and panel now at 45C (heats up within three minutes of being placed in the sun)
Now you have say 2% wiring loss from panel to controller, lose another 4.5w = 224w. Controller loss 5% = 11w means output is now 213w. This is in perfect conditions with panel aimed.
So now you divide that 213 by battery voltage to get your charging amps. 13v - 16.4 amps and 14v - 15.2 amps.
BTW this makes it so bogus when people say you "waste" a bunch of watts when using PWM and you don't waste them using MPPT. The watts with MPPT are less too.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
