BFL13
Nov 07, 2015Explorer II
Salvo wrote:
Let's be clear. PWM never has an advantage. It will always lag MPPT in performance. When comparing apples to apples, under normal operating conditions, mppt will have a 5 to 10% advantage.JiminDenver wrote:
PWM advantage when it is hot is mid day when most of our systems are in float or close to it and again, there isn't much advantage there.
Never say never. :)
Actual results with 255w panel same wiring, same batts just swapping controllers. 25C ambient, 51C panel (IR on back of tilted up panel)
Panel rated Isc 9.0, actual Isc at the time was 9.2 so insolation was STC or better.
Standard PWM (12-12) would get 255/130 x 8.2 = 16a but not possible to measure 12-12 PWM with 24v panel. I was able to measure 24-24 PWM by putting the batts in 24v mode.
Results (mode, battv, output amps, output watts)
24-12 MPPT 13.0v, 15.85a, 206w
24-24 MPPT 27.0v, 7.95a (like 15.9a), 215w
24-24 PWM 27.0v, 7.99a (like 16.0a), 216w
So call the 24-24s equal. The 24-12 MPPT was also equal to the expected 12-12 PWM as calculated at 16a. So really, it was 16a for every situation 12v batt or 24v batts.
And that was all "apples to apples"--same panel, same wires, same batts , same day and time of day.
I do agree that often, the 12-12 MPPT does a little better than 12-12 PWM as Salvo measured in his test a while back and as I have also seen. But as seen above, it is not always so. Never say never!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
