Gdetrailer
Jan 11, 2021Explorer III
otrfun wrote:
jkwilson, thanks, good to know a dc-to-dc charger is capable of voltage compensation.
Gdetrailer, thanks for the explanation. I was aware of some of the various limitations and concerns which is why I posed my question. With dc-to-dc chargers becoming more mainstream and the Ram Cummins being one of the more popular TV's, I was hoping there may be more specific info in regards to what this alternator (and/or a Ford/Chevy HD alternator) is or is not capable of.
FWIW, I believe the stock alternator on a Ram Cummins is rated at 160-180a. Our truck came with the optional 220a alternator. Wouldn't this extra capacity significantly reduce (not eliminate) any concerns about an additional 60a load on this alternator---even at idle?
No "significant" reduction of "concerns", just means the alternator MIGHT be able to provide an additional "burst" of charging current.
Couple of things come into play with alternators, one is the small space provided for the alternator.
To allow for more current, the "windings" in the alternator must be considerably heavier (larger ga of wire). Heavier ga wire means LESS windings in a given space which means the alternator now must physically be larger (circling back to space limitations in the engine compartment) so, what typically happens is the alternator must spin faster with less windings meaning that they have to use a smaller pulley on the alternator to spin it faster..
I remember yrs ago, there used to be an outfit that sold "upgrade" windings for 1950's-1980's alternators which would take a 35A alternator and get you 45A-60A.. The drawback was the alternator was no longer able to generate enough voltage at idle that it would not charge at idle.. Lights dimmed every time you stopped and got bright every time you started moving.. Sometimes you could find a smaller pulley for the alternator and sometimes not..
More current also means that they will have to add several extra diodes in the output of the alternator or use higher current diodes, both of these outcomes requires more internal space in the alternator and additional cooling..
Now days, things have gotten a lot more complicated, most manufacturers have now put the body control computer in charge of the charging system and the body control computer now regulates what the alternator can and can't do.
While you can add in a heavy 12V load for short bursts, I would not really recommend do that for long periods of time like heavy charging of your RV battery under idle conditions..
The exceptions to that would be IF you have a "ambulance prep" type of package, the manufacturers will have modified the electrical system, body control computer and alternator for that type of heavy stationary use..
Something else to consider, prolonged idling of a Diesel can lead to "Wet stacking"..
