RSD559
Jan 13, 2021Explorer
I have the Renogy 50 amp DC2DC that I will be putting into my 2015 F-350. I'm connecting the relay that powers it to an upfitter switch. I only plan on using it when the truck is rolling, but plan on having the high idle set up as a just in case. Note on the Renogy 50 amp charger, if you have solar also connected to it, and there is voltage on the solar side, the charger will only charge 25 amps on the DC2DC side.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
