time2roll
Feb 26, 2012Nomad
KJINTF, I do not plan to drag the data cable indoors. I intend to use only the monitor shown :)
Yes I have the temp sensor but with mild temps it is not on yet. Should have it on before summer. The strain relief for the ground wire has a second hole where the wire will come through.
I have strong doubts I need the sense wires since it is installed so close. If it is off by .1v it will not be an issue.
I do need to change the charge settings. I will temporarily attach the cat-5 and once set forget about it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
